TX100 purple image
Discussion in 'Projectors, Screens & Video Processors' started by cliocarl, Sep 19, 2004.
  1. cliocarl
    cliocarl
    Mar 27, 2004
    337
    Cheshire
    +4
    Hey guys,
    just set up my projector tonight to show the bird and using this crappy £30 dvd player I connected them up via component leads.
    The image was purple mostly in colour! :eek:
    However when using the box standard video input it worked a treat.
    Is this a setting on the projector that I have to change? Im worried that it is the component port that is faulty, but its more than likely that the crappy dvd player is just being crap and its output isnt working very well!
    Anyone any suggestions? or experiences like this?
  2. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    More than likely a problem with the dvd player not being set to output component video, or leads not properly connected or faulty................. Check the settings on the dvd player ('ve got a cheapy for one of my daughters that does prog scan and you have to select the output mode) - if it's not that then make sure the leads are connected properly - i.e. right way around and fully pushed in.
    Sean G.
  3. cliocarl
    cliocarl
    Mar 27, 2004
    337
    Cheshire
    +4
    Thanx for that reply.
    I set up the dvd player again this morning and went into the settings and it was rgb and not YUV so i changed it and its working nicely.
  4. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Good stuff.............. :smashin:
    Sean.
