TX100 component connection
Discussion in 'Projectors, Screens & Video Processors' started by bonfigli, Mar 15, 2005.
  1. bonfigli
    bonfigli
    Hi there,
    I'm ordering my TX100 on Friday :thumbsup:
    I was trying to figure out the best way of connecting up 3 component devices to the projector (sky/dvd/ps2)
    Would this little box do the trick, or is it to cheap and nasty??
    YPbPr Power Box - Selector Unit *takes a couple of seconds to load*
    I was also considering purchasing one of these product's for my ps2, but would this connect to the projector???
    PS2 Hi-Resolution VGA Box / Adaptor
  2. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    dosnt your amp allow component switching ? ive got one cable from amp to PJ and then xbox and ps2 to amp and i just switch between them on the amp
  3. Member 14847
    Member 14847
    Aug 16, 2002
    491
    28
    +54
    What connectors do your various devices have? Sky will need to be converted to component or s-video, does DVD have component and have you purchased the component adaptor for your PS/2? JS Technology do a very good 2 in/1 out component controller and various converters worth looking at. As BauerCTU mentioned, these devices combined with a component switching amp might offer the best solution.
    One other thing to ponder is purchasing a DVD player with HDMI output....
  4. bonfigli
    bonfigli
    Unfortunately, I don't have an amp :¬( but that does sound like the best road to go down!
    Could anyone recommend a cheap one for a newbie?
    I'm looking to connect my dvd/cable/ps2 & i don't know if you can get one that takes a pc (not essential)
    Thanking you in advance
  5. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    +76
    if you dont have an amp how do you hear the material you play on the projector ? you can get component switching amps for under £200 at some online sites. popular ones seem to be Pioneer 814 and the denon 1905
