TX100 arrives tomorrow!!! one last question...
Discussion in 'Projectors, Screens & Video Processors' started by bonfigli, Mar 21, 2005.
  1. bonfigli
    bonfigli
    just like to thank you guys for helping me make this decision over the last month.
    Projector and screen arrive tomorrow, and I have ordered a component cable for my Progressive scan dvd player (sounds like I know what I'm talking about, but I don't really)
    One last question regarding speakers.
    I don't have a clue regarding surround sound, my dvd player/recorder (liteon LVW5006) has a Optical digital cable out, and it says Dolby Digital on the front.
    Does this mean the player does the "decoding" and I just need a set of 5.1 surround sound speakers with optical digital in??
    As you see, I don't have a clue about speakers, I've seen a few different packages, but don't know if I'm looking at the right things.
    Could I connect my Optical digital out to this piece of equipment http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=5761438599
    This probably belongs on another board, but you guy's seem to know everything :D
    Thanking you in advance
    Bonfigli
  2. Timbo21
    Timbo21
    Dec 23, 2004
    4,473
    3
    2
    London
    +263
    Sorry, don't have time cos I'm leaving work now. I had a quick look at that item
    and you'll need a surround reciever to go with the speakers (don't think there
    was reciever with them).
    Basically you put the optical/coaxial feed from the DVD player to the reciever to get the Dolby 5.1/DTS surround which is then decoded and sent to your various speakers. Component is usually fed from the DVD to the reciever as well and then
    onto your TV/screen.
    Hope this helps in some way. I'll have a look tomorrow when there's more time.
    Also, I wouldn't rush into anything. There are some decent packages of reciever
    + speakers with or without DVD player. There isn't a huge choice of budget
    systems packages with just reciever & speakers, most have DVD as well.
    Work out your maximum you can afford and read reviews, do search on forums
    for products your interested in, and if you can, get a demo.
    Good luck,
    Tim.
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    Clarify what speakers / amp you already have and what budget (if any! ;)) you have to get your setup to full 5.1 - we'll do our best to help!
    ...PJ
  4. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,302
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    a nice little Budget amp & Speakers will pair nicely with the machine ;) as PJ says a budget will help us help you. sometimes dont listen as we can ermmm pursuade you to spend more than you were first willing to do so :D i was originally keeping my old amp/dvd/speaker and getting a £600 epson Projector, look at the sig and see what i done :rotfl:
  5. bonfigli
    bonfigli
    Thanks for the quick response guy's.
    Basically, I'm happy with my dvd player just now, and all I really need is some speakers to connect to the dvd player.
    Unfortunately I don't have an amp, and here is the funny bit, I only have a budget of £150 for speakers.
    So at the moment I have no way of listening to my dvd's while using the projector, hence why I thought the ebay set for £130 would do the trick :(
    HELP!!!!! lol
  6. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,302
    71
    +76
    in all honestly your going to be struggling to get some nice sound for that price unless you go for an all in one box. i cant comment on that system of ebay but you pays the money you takes the risk. its worth noting that is it worth wasting the 150 now when that could be saved plus added to for a nicer setup ? denon do a nice budget amp for under £190 with a nice set of tannoy speakers costing you another 150. i can say ive been in you shoes as i had my projector for 2 weeks before i bought my speakers and i could have easily done what your thinking. but im my mind i wasnt spending over a grand on one great component to let the whole system down with other poor one's. just my 2 p worth and probably not what you want to hear at all. i told you we make you spend money you dont have :devil: wait till the upgradeitis kicks in :rolleyes:
  7. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,302
    71
    +76
    something like this will do the trick and will have an in built dvd player http://www.unbeatable.co.uk/CatalogueItem_20095.html
    but your not going to get progressive scan from something that low budget i feel so you could get that and connect you exsisting DVD player to it as well (assuming it has optical in, but im sure most of them these days do at least have one), then you just have a usless dvd player but you dont have to worry about ebay and shipping from germany
    hope this helps and any more Q's just fire away
    edit another one thats in budget with Prog Scan PAL only
    http://www.empiredirect.co.uk/content/products/details/html/SAM-HTDS470RH.htm
    this ways seems like a better solution to a budget and at least you can get reviews for these systems and find one tailored for you
    Jack (now tired from typing :devil: )
  8. yoskiwoski
    yoskiwoski
    May 25, 2004
    328
    +9
  9. yoskiwoski
    yoskiwoski
    May 25, 2004
    328
    +9
    also I got a Marantz SR4300 5.1 amp from Richersounds for £200 that I am very happy with, the newer model sr4400 is only £169 at Richer Sounds you will have to buy the speakers extra but is a good amp, perhaps look for someone selling something similar second hand after an upgrade. (amps last very well unless they are abused)
  10. sainthalo
    sainthalo
    Feb 24, 2005
    630
    19
    2 years ago the flavour around here was the yamaha htib series which had a receiver and 5.1 speakers and bass box. this gave excellent sound for the money about £200. maybe theres one on ebay or you can find one cheap somewhere - they are fantastic for the money. i got i think the HTIB-45 package for £150 from empire in a sale 2 years ago (although they still havent charged my cc...) :)
    -checked and they are discontinued but they do similar ones now with dvd on board. that sony one mentioned above looks a good bet :)
  11. yoskiwoski
    yoskiwoski
    May 25, 2004
    328
    +9
    seems a bit silly to me to have rush in, a decent stereo attached to your current dvd will still be good, it is not a crime to have two speakers instead of five (for a while anyway) I had my stereo amp attached to my dvd for ages before i moved over to 5.1.
  12. bonfigli
    bonfigli
    Thanks again guys for more great help.
    I definitely want to go down the amp route at some point, but I have already kicked the arse out of my original £1000 budget for everything :eek:
    Bauerctu,
    Would I be right in saying that the following http://www.empiredirect.co.uk/content/products/details/html/SAM-HTDS470RH.htm would be able to manage the 5.1 "encoding/decoding"???
    Sounds like a good stop gap till my birthday :D
    Bonfigli
  13. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    That should do the job but it's not multi region by the looks of it - there may be a hack though.
    Richer sounds have a Toshiba system for the same price that is MR...
    http://ws2.richersounds.com/showproduct.php?cda=showproduct&pid=TOSH-SD44HK-SIL
    However if I were you I'd buy a budget AV receiver and speakers separately... Again there are some bargains on the Richer web site, elsewhere too I'm sure. This way you are not re-paying for a DVD player that you don't need...PJ
  14. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,302
    71
    +76
    problem is here that for £150 your not getting very far in regards to separates. its a pity that unbeatable dont have the yamaha amp/speakers deal for £150 any more as that would be perfect.
    edit just found it if you can stretch your budget a tiny amount more then your sorted http://www.unbeatable.co.uk/CatalogueItem_21653.html
    this is perfect for you and its a separates system :D looks like we have done it
  15. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    amazing value :thumbsup: ...PJ
  16. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,302
    71
    +76
  17. bonfigli
    bonfigli
    Can't get the two search links to work :confused:
    The package looks good, but what is the benefit of having the receiver, never had one?
    Does it do the "encoding" and produce better sound rather than the dvd/speaker package mentioned previously??
    The price looks good though :thumbsup:
    Bonfigli :clap:
  18. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,302
    71
    +76
    yes the seperates will be better than the all in one box. the amplier will do all the ness audio decoding for you and it has 2 optical inputs to connect you DVD player to. have fun
  19. bonfigli
    bonfigli
    :D :D :D :D :D :D :D :D :D :D
    Sorry, that is the only way I can describe the joy I experienced when I displayed my PJTX100 onto my wall for the first time last night.
    I ordered the Yamaha amp/speaker bundle today, and it arrives tomorrow.
    And I fit the screen tonight :thumbsup:
    Many thanks again for all the help.
    No doubt I'll be back on tomorrow with more questions
    Bonfigli :clap: :clap:
  20. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,302
    71
    +76
    glad you like it. dont forget to add to the "show us yours" thread
