TX100 and 720p
Discussion in 'Projectors, Screens & Video Processors' started by CrackDown, Jun 28, 2005.
  1. CrackDown
    CrackDown
    May 25, 2003
    391
    +26
    I have a Pioneer 575 hooked upto my TX100 via component. Now I've just downloaded a hd trailer for king kong which is 720p, and i burned it to a cd and tried to view it. I assumed the projector was gonna switch to hd, but it doesn't. I can hear the trailer however. This is the first time ive tried viewing hd before. Is it a problem with the player? or projector?
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    are you viewing it on a dvd player? As most will only put out SD.
    I'm guessing the file is divx? try hooking up your pc to the projector if it is at all practicle, just to make sure it works.
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
    Yes as Gaz says a normal DVD player such as the 575 will only output standard definition (SD) hence it's not really worth it....PJ :)
  4. Maff et1
    Maff et1
    You need to attach your computer to the PJ, spend several hours (days possibly) playing arround with graphics settings to get a 1:1 match with your PJ and then you can watch the trailer in HD from the 'puter.
  5. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
    As I've said before, HTPC = Happy Times Parameter Changing :D
  6. Maff et1
    Maff et1
    In my limited attempts at getting a Tosh ET1 (848x480, don't laugh) and a radion 9200 to agree I don't remeber ever being 'happy'
    I gave up in the end, used 1280x720 for the PC (scales about right) and a pio 575. Much easier.
  7. sainthalo
    sainthalo
    Feb 24, 2005
    630
    19
    Just to flip the coin on this...
    Pairing my HTPC to my Z3 was a breeze. DVI to HDMI connection. No need for powerstrip since ATI drivers include 1280x720 settings. FFDshow set up following settings an AVSforums and playback in WMP10 and VLCplayer. Took me an hour or so really with another hour or so reading forums for tips. Dont own a standalone DVD player, and dont want to! :thumbsup:
  8. CrackDown
    CrackDown
    May 25, 2003
    391
    +26
    Thanks guys. I just assumed my dvd player could player a higher resolution xvid.
