Tx-nr609 +low frequency speakers for apartment (experts help pls)
Discussion in 'What Speakers Should I Buy?' started by couto27, Jan 9, 2012.
  1. couto27
    couto27
    Jan 9, 2012
    465
    2
    46
    UK & Portugal
    +121
    hi, this is first home cinema step up, I'm going to buy a tx-nr609 onkyo, but i need some speakers + subwoofer to go with.
    living room- 30ft x 15ft ( cinema area 7ft x 7ft )
    budget - 500£ max
    since i live in a flat with thin walls, the most important feature will be:
    1-speakers low frequency (to hear every single cinema sound with low volume)
    2-cinema use, tv, blu ray.
    3- small speakers with style design 5.1
    4- wall mounted.
    5-subwoofer wall mounted if possible (don't want a hungry neighbor on my back)
    Room acoustic
    floor is marble stone with a big carpet.
    walls are thin made with brick and stucco (not ciment)
    ceilling is ciment and stucco
    i don't know what speakers will sound best in my living room, but i search some models by their reviews, awards, and price.
    Receiver onkyo tx-nr609 (160w - 106db )
    1- onkyo sks-ht648 ............................. low frequency 70hz (200£)
    2- Boston Acoustics Soundware XS5.1SE... (350£)
    3- Canton Movie 160 mx ....................... low frequency 65hz (500£)
    4- Tannoy HTS101.................................(500£ )
    5- Wharfedale DX-1HCP......................... (400£)
    6-canton movie 125mx...........................low frequency 120hz (250£)
    7- -.......open to sugestions :lease:
