TX-HX700B AV input retrieving data???
Izzy2502
New Panasonic TX-HX700B AV input showing 'Retrieving Data' with nothing connected to it.
Anyone any ideas? I would ask Panasonic but there is probably more expertise on here.
TIA
Izzy2502
Yes been off and on a few times. The other inputs (hdmi, VGA etc) are either blank screen or 'no signal' as you'd expect with nothing connected.
Retrieving data seems bit odd.
JayCee
The “Retrieving Data” message could be a software or EPG update but as to why it's showing that on AV with no input is strange.
Try connecting something to the RCA AV input, e.g. a DVD player or anything with composite or component video out and check if it gives a signal.
Izzy2502
I connected an old camcorder to the AV inputs and it played ok. Thanks for the suggestion.
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
