TX-65JZ1500 Wall mount dimension?
Beemer3
My TX-65JZ1500 is still in its box and I shall wall mount it using a Sony SU-WL850 bracket. My studded wall was custom made to fit a bracket for a non VESA TV and so I cannot rely on industry standard vertical or horizontal stud pitch. The Panasonic TV manual does not show the height from the bottom of the TV to the bottom VESA hole. It is this dimension that I am seeking. I would be grateful if anyone would confirm this dimension before I start drilling too many test holes! Our room is in the middle of renovation I would prefer to leave the TV in its box until the time to lift it into position.
NordpolAnton
Hi! I have got the exact same TV and the same Sony wall mount.
The height from the bottom of the TV to the bottom VESA hole is exactly 12,5 cm! :)
Beemer3
You are a star! Many thanks I'll get the bracket up today. Hopefully this won't happen!
television set GIF by The Room
Beemer3
I tried to use a new stud detector but it was so unreliable. I reverted to the age old method of drilling many small holes. I got lucky and was able to find studs for all four coach bolts.
