TX-32PD50 max resolution as a HTPC display?
Discussion in 'General TV Discussions Forum' started by nikosz, Jan 2, 2005.
  1. nikosz
    nikosz
    Does anyone know what is the maximum progressive scan lines that the Panasonic TX-32PD50 can display when driven via the RGB input?
    A press release mentions 75 MHz processing which if it were the same as bandwidth it would mean that it can handle 1080p. Is that right?
    Are there any other CRT TV sets marketed in Europe that can handle 1080p?
  2. peahead
    peahead
    Dec 14, 2002
    3,000
    St.helens
    +384
    no not 1080p but jvcs tv do 1080i apparently.
  3. Shaddow
    Shaddow
    the only crt tv with 1080i is JVC HV-32P37SUE?
    PD50 supports 420p, 720p?
  4. nikosz
    nikosz
    Can somebody confirm 720p? What resolution did TX-32DP30 reach?
    In general what technology do you people prefer for HTPC?
  5. Eiji
    Eiji
    Feb 16, 2005
    1,422
    48
    +69
    So does the PD50 support 720p too or only 480p/576p?
  6. peahead
    peahead
    Dec 14, 2002
    3,000
    St.helens
    +384
    No it doesnt support 720p dont think any crt tvs support it well not in the uk anyway.
