Two Xbox Av sockets in One Xbox!?!
Discussion in 'Cables & Switches' started by whiteboy7, Sep 13, 2004.
  1. whiteboy7
    whiteboy7
    HI!
    I need to use a Component and RGB Scart connection and a optical digital out at the same time.
    Do You guys think that dublicating the av socket in the back of the xbox is possible?
    I probably cant buy a Av-split cable, and probably have to make this myself...
    It would be pretty sweet, if it's possible - so I can use more connections at the same time...(IF possible)
    / Thomas
