Two VCR's in setup
Discussion in 'Digital TV & Video Players & Recorders' started by Neil_F, Jan 17, 2003.
Tags:
  1. Neil_F
    Neil_F
    Hi all,
    Is it possible to connect 2 vcr's in a setup in series?
    My setup now, using scarts is:
    SAT > VCR > TV (composite)
    SAT > DVD > TV (RGB)
    I was thinking of:
    SAT > VCR1 > VCR2 > TV (composite)
    There is only 1 SAT box in the setup.
    I would like to (possibly) do tape to tape recordings.
    Would this setup allow recording on one VCR whilst playing back the other VCR?
    I know I should be going down the digital route but I am being cautious about the format war and have you seen how cheap VCR's are at the momoent.
    Neil
  2. phil r brown
    phil r brown
    Absolutley yes... you can string as many VCRs as you like... but be sure they have 2 x scart sockets.
    Yes once done you can record Vcr to Vcr... play on one and just select the appropriate AV source on the other and record.
    phil
