Two Towers Encoding Problem?
Discussion in 'Movie Forum' started by russraff, Aug 15, 2003.
  1. russraff
    russraff
    Aug 1, 2000
    2,322
    Newcastle
    +53
    I have just watched The Two Towers (region 1) and though the film is great (not as good as the first, though) I experienced some strange "encoding problems" during the battle of Helms Deep. There would appear to be red flashes, or glints, throughout the battle. A bit like the afterglow some old Dr Who episodes used to have when something bright moved across screen. Now, it may be particular to the equipment that I am using, but these glints don't seem to appear during slow motion. This is why I think it might be a problem with the disc
    Can anyone shed some light on this, or is it just me and this is actually supposed to be there?
    Pioneer 656 on a Toshiba Rear Projection TV
    Russell
  2. Zone
    Zone
    Jun 24, 2001
    6,570
    Barnsley
    +2,190
  3. Riker
    Riker
    I noticed this too. I am using a Sony DVP S725D. Like you say there is some Red "Ghosting" in the Helms Deep battle and also at the beginning when the 2 hobbits are escaping the urukai (Excuse spelling) just before they enter fangorn forest
    Anyone else notice this?
  4. johna
    johna
    Dec 15, 2000
    864
    Kent
    +3
    me too - i thought it was a dodgy disc but obviously not. Maybe it wont be there on the extended edition, but it is very noticable
    i was using a tosh sd900e
  5. Rochdale
    Rochdale
    Mar 16, 2002
    359
    Leeds, UK
    Didn't notice anything when I watched it, I'll have another look.
  6. russraff
    russraff
    Aug 1, 2000
    2,322
    Newcastle
    +53
    This is a shame as it detracts from the enjoyment of the film. Does anyone have the R2 onwards version, and does this version display the same problems?
    Russell
  7. Mr.D
    Mr.D
    Jul 14, 2000
    11,061
    +1,149
    I didn't notice any problems on the region1.
  8. CarlB
    CarlB
    Jan 8, 2001
    1,108
    Godmanchester, Cambs
    +96
    I also noticed no problems on the R1 disc. I have just rewatched the scenes in question and could see no red 'flashes' at all, at either normal speed or in slow motion.
    I would also suggest that it is unlikely to be a problem with the encoding if they are not visible in slow motion. The problem is either on the disc or it is not, and playback speed would then not be a factor.
  9. steve1056
    steve1056
    Apr 20, 2002
    374
    Reading
    +5
    I just watched the scenes in question a couple of more times today and there is absolutely nothing wrong with the picture on my R1 version. FYI, I have a Sony 725 DVD player like Riker.
    Cheers,
    Steve
  10. johna
    johna
    Dec 15, 2000
    864
    Kent
    +3
    I just checked another R1 disc on my player and it was fine - must a batch of dodgy discs.
    I'll just give my dodgy one to my bro' and keep the decent one.
  11. one_jedi
    one_jedi
    Could it be something to do with a combination of the dvd, the dvd player and the television. For instance whe I play Way of the Gun region 1 on my dvd player on my TV the geometry at the top of the screen is really really bad, all my other region 1 dvd's are fine. But when played on my dvd player or another dvd player on another TV this problems isn't there! The DVD just doesn't seem to like my Television. Also this is only when it is played in NTSC if I put my player to Pal (Pal 60 as my plaer has) then this problem dissapears! Don't ask me why this happens but it does!
    Has anyone tried to see if this problem is there on NTSC and Pal 60, shouldn't make a difference but you never know!!
    Also have people tried the DVD on tottaly different set ups or with thier dvd player but using a different TV?
    Fianally what type of connections are you using? Component, RGB scart or S-video, can't see why this would make a difference but you never know.
    Like somone said I would have thought that it would have been there on slow motion as well as normal speed if it was the DVD which maybe means that when played at speed theTv's just don't like it?
  12. one_jedi
    one_jedi
    no comment on any of this, anyone else who now have copies notice this?
  13. eel
    eel
    And hear was me just expecting a mess of pixelation on the r2 version!
  14. russraff
    russraff
    Aug 1, 2000
    2,322
    Newcastle
    +53
    I am using a Pioneer 656a with a Toshiba Rear pro TV. This is looped through my amp, which is high def compatible, so I shouldn't think it's that. All connections are Component. I have tried my disc on a pioneer 525 rgb to a JVC TV and the problem persists.
    I am leaning towards thinking that this is a few bad discs, rather than peoples equipment, but I still don't understand why it doesn't appear in slo-mo.
    I haven't tried PAL 60, I will give it a shot tonight.
    Russell
  15. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,840
    Somewhere in South Yorkshire
    +5,067
    Only watched the R1 item once - didn't notice any such artefacts. That's not to say they aren't there - I just didn't notice so I'm not sure. Post some precise chapter/time references and maybe I'll take another look.
  16. othello
    othello
    Oct 9, 2001
    147
    16
    england
    i noticed a glint in the battle of helms deep.it was like light shining off armour..only lasted about 20seconds at most..that was my only complaint and that is very minor..either it is a problem with the disc or a part where the transfer is not at it`s best..
  17. Gatto
    Gatto
    Its the same on mine but its more than 20 seconds, it within all the battle, will you be asking for any replacements??
    The equipment is the following :
    A NAD t531, connected through an RGB cable to a Philips 32PW8717. No probs at all with other films, just this one
  18. othello
    othello
    Oct 9, 2001
    147
    16
    england
    nope it don`t bother me that much m8...i`ll be getting the extended version anyway..as long as that is up to stratch then i`m happy.
  19. russraff
    russraff
    Aug 1, 2000
    2,322
    Newcastle
    +53
    Yep, that's what I'm doing. The 2 disc version isn't even mine, so I will leave it to them to decide whether to exchange it. In fact they didn't notice the red bits, so they're happy and will probably remain so unless I point out the defect (which I won't)!
    Russell
  20. Steve T
    Steve T
    Aug 30, 2000
    438
    Redditch
    +3
    I can't say that I saw it during Helms Deep but think I may have seen it in the early battle where Eomer and the Riders of Rohan attack the Uruk Hai and Merry & Pippin escape. It's the first time you see Pippin nearly get run over by the horse.
    I'll have another check later. The kit is a Pioneer 545 DVD player, Ixos RGB scart to a Toshiba PF2 36" TV.
  21. Gatto
    Gatto
    It seems that you have to play all the film from the begining to encounter this problem, if you go straight from the menu to select a scene it will be displayed correctly!
  22. Mr.D
    Mr.D
    Jul 14, 2000
    11,061
    +1,149
    I watched it again last night...no problems.
    However it does stick on the openign New line credit ( the dvd one not the actual title card version on film).I have to use the chapter select to start the film. I'm using theatertek on an HTPC . No problems with artifacts on the picture though. Strangely FOTR has similar issues.
    Also found my HTPC was missing half its RAM! reseated the wafer and ping its back again. The joys of home cinema!
  23. Droogie 2001
    Droogie 2001
    Aug 19, 2001
    1,390
    Surrey
    +69
    Just thought I would add my observation of red flashes on the Helms Deep battle.
    Didn't see it at Fangorn Forest bit though.
    I have a Pioneer 717 and was outputting RGB .
    The disk was rented from my local video shop as I am waiting for the extended edition.
    Do we have EIV to blame again for this?!:(
  24. Rob Pyatt
    Rob Pyatt
    I didn't notice this on my R1 copy.
    That is on a Pioneer 626D connected via S-Video to Panasonic PTAE100E projewctor.
    I had drunk most of a bottle of wine by then tho!
  25. Darth_Fisto
    Darth_Fisto
    Feb 22, 2003
    209
    Scotland
    +16
    I have the R2 release and there is NO red flashes or imperfections of any kind. Great transfer to my eyes (and ears :D ).
  26. MonkeyDonkey
    MonkeyDonkey
    May 9, 2002
    401
    UK
    I rented the r2 from blockbuster today and the red flashes were visible. There also seemed to be something wrong with the colour (or the lack of it to be precise) on certain shots. Although this is possibly my setup or maybe even my mind playing tricks.
  27. Jase
    Jase
    Mar 16, 2001
    9,527
    UK
    +925
    Got the R1 Canadian release and and not seen these problems on my Toshiba SD900 using the progressive output.
  28. puddleduck
    puddleduck
    Jan 24, 2003
    1,816
    48
    Lake District, near as dammit
    +50
    Watched this last night (R2) and didn't notice this. Was projecting an 8 foot image, so if it was there, I'd seen it :)
    Anybody got a time stamp for this so I can double check?
  29. CMcK
    CMcK
    Mar 18, 2003
    391
    Scotland
    +28
    Finally got round to watching LOTR:TT last night and I also have the red flashes problem. I noticed the problem during the scene when the Riders Of Rohan attack the Orcs at night.
    I could even make out blocks of various shades of red where it should be black.
    I have a Pioneer 717, QED Squart (RGB only) and a Loewe Aconda.
    I am going to return the disc today, has anyone else tried returning the DVD and had any success with a new copy.
