Two Towers EE, R2: problems with audio commentary track
Discussion in 'Movie Forum' started by NicolasB, Nov 24, 2003.
  1. NicolasB
    NicolasB
    Oct 3, 2002
    6,454
    Emily's Shop
    +898
    I'm wondering if this is a problem with the disc or with my player (original model Arcam DV27).
    When I try and play one of the audio commentary tracks, it refuses to do it. On the first disc it sometimes works - on the second it never works. If I select an audio commentary from the menu (either the one you get as soon as you put the disc in, or the one you get to after hitting "Menu") then it starts playing the film with the normal film sountrack and subtitles active.
    If I start playing the film normally I can then switch between audio tracks, including the commentaries - but there's no way to activate the thing which tells you who is speaking at any given point.
    I've noticed other problems too - behaving as if I had pressed "stop" when I'm trying to navigate a menu - but these are sporadic errors, and could be to do with interference problems, or something like that. But the commentary track problem on disc 2 is absolutely consistent. :(
  2. Dellboy
    Dellboy
    Apr 24, 2002
    602
    43
    The Cotswolds
    +135
    Yep.
    I'm also having the same problem.
    The menus do not active the commentaries on both my discs. I'm having to get round the problem by selecting the appropriate sound track using the audio select on the remote.
  3. NicolasB
    NicolasB
    Oct 3, 2002
    6,454
    Emily's Shop
    +898
    What type of player do you have, Dellboy?
  4. Dellboy
    Dellboy
    Apr 24, 2002
    602
    43
    The Cotswolds
    +135
    I have a 13 month old FMJ 27.
    Perhaps a few more responses will determine weather this is a problem on this particular machine
  5. Racquel Darrian
    Racquel Darrian
    Aug 18, 2003
    3,147
    +683
    My mate is having the same problem on his old Lecron.
