Two subs?
Discussion in 'Subwoofers' started by parkem50, Aug 23, 2004.
  1. parkem50
    parkem50
    Mar 12, 2004
    34
    Norfolk
    Sorry if this thread has been done before, but how do you drive two powered subs if you're amp only has one sub output?
    Upgrade me thinks!!
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    use a Y connector that splits one output from the amp into two leads
  3. parkem50
    parkem50
    Mar 12, 2004
    34
    Norfolk
    Thankyou!
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Or you could upgrade to a model that has 2 sub outs (usually very expensive) or use the low-level interconnect from one the main left pre-out to underpin your main speakers rather than deal with the LFE signal. Depends what sounds best to you :)
  5. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,136
    2
    +3,587
    Alternatively, many subs have an in and an out for just this reason. My sub out used to travel from amp to sub number 1 and from there to sub number 2.
  6. parkem50
    parkem50
    Mar 12, 2004
    34
    Norfolk
    all good advice! Thankyou!
  7. Stellavision
    Stellavision
    Apr 7, 2003
    2,343
    Southsea, UK
    +101
    Just be aware that two subs can be a real pain to set up.
    One better sub is often a better option, although some people have had good results from a dual sub setup.
