Two Subs or One?
Discussion in 'Subwoofers' started by johna, Aug 13, 2001.
  1. johna
    johna
    Dec 15, 2000
    880
    Kent
    +9
    Should I buy Two B&W ASW500 - Or One M&K VX100?
    I am going to audition later this week but any ideas greatly appreciated.
    John
  2. russraff
    russraff
    Aug 1, 2000
    2,458
    Newcastle
    +80
    The consensus is that two subs are better than one. I must admit that I have been thinking of dual subs lately, and question I ask myself is: "How cheep can you go before you start adding more bad noise?” I reckon that if the sound of a single sub does something for you, then buying two will only enforce that view, rather than be overkill. Seems obvious, but originally I thought that two subs would cause all sorts of bass cancellations and such. Try setting up just one REL Strata III - you'll be on the job a fortnight getting it right, so what will two be like? Hearing two subs in a demo room was a revelation. Everything was just so right and "even". Personally, I'd go for the dual ASW500's (if they sound good - had a home demo?)
    Russell
  3. johna
    johna
    Dec 15, 2000
    880
    Kent
    +9
    No I haven't had a home demo - I can pick up the ASW 500 for abou £350/375 EA but that's from Tottenham Court road - so I think a home audition would be out of the question, I will definitely demo in the show room though.
    The killer question is:
    Is one high end market sub better than two mid range!
    But the only way I can tell is by trial I suppose
  4. Guest
    I asked this question to M&K- Q. Should I go for two v1250thx or one mx350thx? A. Go for one MX350thx as it is a much better sub(two 12inch drivers in a push pull config)
    My advise would be to try and find a dealer who will let you do a comparison in your home
  5. Guest
    How big is your room?<br />Do you listen to alot of (real) music?<br />I have no experience of the BW500 but have played with the larger/older models of which they were all very good.<br />The MK 100 is a super super sub and normally i find i am the world's biggest advocate of (at least) 2 sub set-up's.<br />But not knowing how good the BW's are and knowing how good the MK is your point of "beauty and/or the beast" is well founded.<br />In a very small room you would most likely find the MK more than enough but still prone to the acoustic variances/pitfalls of a single sub set-up. Unless you find the MK to be leagues ahead of the BW's in all-round performance i would invariably take the 2 sub option.<br />Be very clear and honest with yourself as to what it is exactly you want from a sub - it's an expensive mistake to make!!!!!<br />If you want blood and thunder then buy blood and thunder and be happy if you want subtlety and nuance then buy that.<br />Always take plenty of known material to test and take your time, try and obtain test disc's also this will tell you how efficient the cross-over is, how low it will go and cross-over points for main speakers if large etc etc.
    [ 13-08-2001: Message edited by: SteveEX ]</p>
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Personally, having just put an ASW 5600 in today, I would go for the twin 500's. The MX100 is designed to fit into situations where a small sub is wanted, so you are paying for the 'convenience' as well as the sound.
    The 500 doesn't suffer from this, so using two of them should sound great!
