Two stupid questions..me thinks
Discussion in 'Digital TV & Video Players & Recorders' started by ani4ani, Feb 18, 2003.
Tags:
  1. ani4ani
    ani4ani
    Nov 12, 2001
    2,007
    Belper, Derbyshire
    +179
    I have Sky+ and fancy buying a second box for the normal freeveiw channels. I am not interested in the second subscription route with Sky. I only have the sports channels and I will not be sitting in the kitchen or bedroom to watch them.
    Basically this so the kids can watch the usual kids channels etc. [I cannot receive terrestrial channels]
    I want to install the new box with the existing sky+ to save all the wiring etc. I use video transmitters to transmit all over the house.
    First Question.
    Can I use a standard sky remote and the sky+ remote to control the respective boxes without effecting each other. The intention would be to have a standard sky remote in the reception areas - would it change the channels on the Sky+ box?
    Second Question. [rather depends on the above answers]
    Can I split in someway a signal from the LNB to feed to the additional box to save cabling or do I need to seperately connect to LNB. I guess that is above is yes the channels will change then I will locate the additional box elsewhere and cable directly and also eliminate the remote problem
    thx for replies
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    1) The codes for SKY+ and the standard digibox are different so they can be used in the same room together and not just to p**s me off and make my Pana VCR useless for controlling SKY+ :)
    2) You can split it but there will complications involving voltage switching sent to the LNB and the fact that a LNB can only be on one polarity and band at any one time.
    For a normal home there is no practical option but to run an independent connection to the LNB for a second digibox which allows it full access to the channels available.
    You will also need a BBC FTV smartcard for the standard digibox.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    IIRC $ky+ has 2 tuners and therefore is supplied with a double LNB.
    Don't know if this would work but could you not take one of the LNB signals to another digibox?
    Mark.
  4. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    I have Sky+ and it was supplied with a Quad (4 output) LNB as standard. So going back to the original poster's question... the best option is to connect the additional digibox to (one of the spare F-connectors on) the LNB separately with a new cable run. The videosender route is in fact unecessarily complex.
  5. ani4ani
    ani4ani
    Nov 12, 2001
    2,007
    Belper, Derbyshire
    +179
    Thanks for the repies. What is the Video sender complexity. I want to transmit pictures to 5 televisions from either box [kitchen, two bedroons, office and a conservatory] - can you advise a simpler approach? I live in a house that was wired with a single point in the living room. Short of re-wiring to every television, the video sender route seems the cheapest and cleanest.
