two sources at same time on lumagen PRO HDP
Discussion in 'Projectors, Screens & Video Processors' started by brendank, Feb 20, 2005.
  1. brendank
    brendank
    Dec 13, 2003
    684
    drogheda, co louth,ireland
    +6
    Is this possible
    i am currently using it upstairs with panny plasma and am now considering running through it which is located downstairs.
    can the downstairs pj and upstairs plasma be run at same time through the scaler if yes how do i operate it downstairs?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,934
    The Borders
    +3,576
    brendanuk
    You cant view Different sources simultaneously.
    You can feed two Displays simultaneously from any Non HDCP sources - you can output a Digital + Analogue signal from the Pro; though both outputting the same signal format.
    If you want to feed two displays from a single HDCP sources and both Displays are HDCP compliant then you'll need a DVI Distribution Amp on the Output of the Pro.
    Best regards
    Joe
