two sky boxes
Discussion in 'Sky Digital TV Forum' started by bob1, Mar 27, 2006.
  1. bob1
    bob1
    Nov 7, 2002
    4,472
    Sheffield
    +133
    Is it possible to run two sky boxes off one dish ,i bid on two sky boxes on ebay and won both (don't bid on ebay when drunk,it doesn't work),i might keep the one i have and one of those off ebay if you can run both.
    Thanks.
  2. jackal
    jackal
    Yes, you can, You'll need a double LNB for two stadard sky boxes or a quad LNB if they are SKY+ boxes.
  3. phil woods
    phil woods
    i might be wrong but i am sure that you cna purchase twin LNB's for Sky dishes anymore. This means you will need a quad i belivee they are approx £25.00 from most online retailers and are very easy to install.
  4. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    The following is a quote from www.satcure.co.uk regarding twin LNBs:
    "Note: Most Twin-output LNBs for Sky minidishes are no longer available. Allegedly, BskyB removed them from the market because of technical problems caused by independents fitting them badly or to the wrong dishes. The good news is that we've been able to reduce the price of the Quad-output LNB so you can use that instead"
  5. phil woods
    phil woods
    Neil just been on that site and i was dissapointed with the prices they want up to £60.00 for a quad when you can get one from DAS for £26.95 + vat and the site is easier to navigate url is http://www.dastv.co.uk/Shop.aspx
  6. pieguts
    pieguts
    Dec 4, 2005
    155
    Just bought a quad LNB for A tenner.Alot of them were BUY IT NOW,for £13.
    Fitted it yesterday,very easy just swap it over.Now have Sky downstairs and upstairs off two seperate boxes.
  7. Archie Fax
    Archie Fax
    Nov 23, 2003
    233
    Kent
    +10
    General useful tip....
    Quad lnbs are a lot heavier than single lnbs, and extra weight can cause the dish's feed arm to drop. Check the signal quality after fitting one. If it's less than 40% then the dish will most certainly need re-aligning.
  8. phil woods
    phil woods
    Are the Quads from E Bay guaranteed?
