Two Sky+ Boxes at same address
Discussion in 'Sky Digital TV Forum' started by Lemm, Aug 26, 2005.
  1. Lemm
    Lemm
    Dec 31, 2003
    116
    Loughborough
    +7
    Quick question if anyone can help.
    Does anyone know if you can have two Sky+ boxes on the same account. i.e. one upstairs and one downstairs, and if you can, do Sky charge extra (more than cost of standard multiroom)?
    Cheers. :)
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Quck answer ;)
    Yes, I have it set up just like this, no additional charges compared to std. multiroom except if you pay £10/month for your Sky+ (i.e. aren't on one of the premium packages).
    Hope this helps :)
  3. Lemm
    Lemm
    Dec 31, 2003
    116
    Loughborough
    +7
    Excellent.
    Another quick question, if I get another box will I need a Sky installer round to set it up, or is it just a case of un-plugging my "normal" digibox and plugging the Sky+ box in? :confused: :)
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You will need an aerial contractor or Sky installer to run an extra LNB feed because Sky+ boxes require 2 feeds.
  5. Light_User
    Light_User
    Feb 10, 2005
    301
    +7
    I'm sure that I seen a thread saying that you can use a Sky+ box with only one feed. However, you will only be able to record one channel at a time and also have to view that channel whilst recording. I don't think that you will be able to pause a program either ?
    Try doing a search.
  6. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You can use one feed, but it gets very tricky. You have to leave the box tuned to the channel you want to record if you want to make a recording, and recording several programmes unattended (like when you're on holiday) is a nightmare, requiring you to set up "dummy" recordings to force LNB1 to the correct channel. Not something I would recommend if there is an alternative.
  7. Lemm
    Lemm
    Dec 31, 2003
    116
    Loughborough
    +7
    Cheers for the help guys. I'm going to call Sky later and see what they can do for me. :)
  8. TrevP
    TrevP
    Do you already have a Sky+ box ? If so you should already have a quad LNB,with 4 outputs, with 2 feeds to the existing, and 1 to the legacy digibox and a spare, therefore it would only be a case of running the additional feed from the spare to the 2nd SKY + box, with out the need for an installer....
  9. Douzeper
    Douzeper
    Aug 22, 2004
    190
    16
    Antrim, Northern Ireland
    Any idea on cost if you order another sky+ box?
  10. Lemm
    Lemm
    Dec 31, 2003
    116
    Loughborough
    +7
    Yes, we have a Sky+ box downstairs and the second box is in my bedroom.
  11. HMHB
    HMHB
    Nov 11, 2001
    25,558
    Nottinghamshire
    +3,886
    I'd be interested to know how much Sky charge for this as I currently have Sky+ and normal Sky for the mirror sub and would like to have Sky+ in both rooms.
  12. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The cost is the price of a second box (£49 for standard box, £99 for Sky+, or £199 for Sky+160), and £10 a month for the second card. The second card will mirror the channels that you have on the first card. Standard installation is free if Sky supply the box.
  13. Douzeper
    Douzeper
    Aug 22, 2004
    190
    16
