Two RGB outputs on SKY+
Discussion in 'Blu-ray & DVD Players & Recorders' started by Thenewhouse, Mar 20, 2005.
  1. Thenewhouse
    Thenewhouse
    Mar 1, 2005
    Because I wish to use digital audio from my Tosh to the TV (disablling RGB pass-through), enjoy RGB quality while watching SKY and record in RGB quality from SKY, I need two RGB outputs from my SKY+ box.
    As AV1 is the only RGB enabled connection on the Sky+ box I searched the web to find a splitter/amplifier with at least two outputs.
    I came across the following bargain and thought I would pass on to all - The Famous ThreeDoubleYou Company is selling the “Two way SCART Splitter/Amplifier” for £30 and it comes with a free Flat SCART lead.
    http://www.electrashop.co.uk/distribution.htm
    I have ordered mine and will post the results.
  2. Thenewhouse
    Thenewhouse
    Mar 1, 2005
    All
    RGB distribution amp arrived today, as promised complete with a very impressive flat corded SCART lead.
    Plugged the input of the unit into AVI on the Sky+ box and the two outputs into the Tosh and TV.
    Tried a swapping around SCART connections to see if there was any detectable signal loss or interference - none as I could see.
    All in all a successful project at a bargain price...
    So, if anyone is short of the odd RGB enabled SCART connection I can recommend this unit as an effective work around.
