Two Quick Questions
Discussion in 'Plasma TVs' started by Billyfergus, Feb 2, 2005.
  1. Billyfergus
    Billyfergus
    1. Sure it is on the long LG thread somewhere, but can somone tell me the way to access the service menu (PX11)
    2. I know all about transportation only in the vertical position but if your method of transport cannot do this would it be advisable to trasport in a "tilted" method i.e. at 45 deg.
    If it is possible then what way? with the grass tilted forward or backwards?
  2. absthechatter
    absthechatter
    Nov 27, 2004
    159
    1. Press menu button on remote and keep pressed, then press menu button on screen at same time and keep pressed. After about 5 seconds or so, the service menu should appear. Use yellow button on remote to scroll through screens.
    2. It is possible to have at angle, just not advisable in case glass breaks - but if securely fixed I do not think it will be too much of a problem....... unless anyone else knows different???
    Abs
  3. fitguy
    fitguy
    Jan 4, 2005
    104
    +3
    I think we came to the conclusion the reason panels should be transported vertically is so nothing gets loaded on top of them (theres a cracking (!!) picture on here of a destroyed viera that had stuff loaded on top of it somewhere).
    Personally I would have it glass up, only so there is absolutely no pressure on the glass which will flex and possibly damage some of the internal parts.
