two quick question about Sky hd HDD + firmware?
a5ian300zx
just have two simple questions tried the search but does not answer my questions specifically.
1) if I do a firmware update would i loose saved content on the HDD? also does anyone know the latest version for the samsung hd box (mind tends to freeze a lot result in powering down from the mains)
2) is there any way to copy content from the sky box to PC without opening it? (don't want to void warranty)
thanks
a5ian300zx
HDCriticalFan
No. You won't lose it either ;)
No.
Although I wouldn't worry too much about voiding warranties. For all the boxes I've seen the only obvious signs of "tampering" you leave are the damage to a sticker inside the box. I don't think that any Sky installer swapping a box will ever open it up to check for this !
Regards
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
