Two PDR10s or one Rel Q200e?
Discussion in 'Subwoofers' started by Gary Lightfoot, Jan 25, 2004.
  1. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,418
    Surrey. UK.
    +2,083
    Hi all,
    I was wondering what two Paradigm PDR10s would sound like in a room 11.5ft wide by 17ft long compared to the single Rel Q200e I'm currently using.
    I have both - the Rel in my loft cinema room, and the PDR10 in the lounge. I've compared them both and the Rel doesn'ts seem much better for movies, so if I was considering adding a sub, another PDR10 woule be considerably cheaper.
    Any comments appreciated.
    Gary.
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,418
    Surrey. UK.
    +2,083
    Bumperoonie...
  3. SamirP
    SamirP
    Apr 28, 2003
    1,232
    South Of The River
    +32
    Hi Gary
    If you thought that the Q200e was only a little better than your PDR10, then why not upgrade the loft Sub instead of adding a second
    PDR10 to PS1000 was a big improvement
  4. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,418
    Surrey. UK.
    +2,083
    Good point. :)
    PS1000s aren't to expensive, so I'll keep my eye out for a second hand one on the forum. Think it'll be as good as 2 PDR10s, or better than the Rel? Sounds likely - for movies anyway...
    Cheers.
    Gary.
