Two optical cables into one input
Discussion in 'Cables & Switches' started by tobyjuggler, Jan 20, 2005.
  1. tobyjuggler
    tobyjuggler
    Nov 4, 2004
    629
    I have two devices with optical outs, but only one optical input on my AV amp. Is it possible to get a device (switch perhaps) to allow either input to be selected for use with the amp without having to keep moving cables? Automatic switch would be best, but manual will suffice.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
  3. tobyjuggler
    tobyjuggler
    Nov 4, 2004
    629
    That'll do me. Thank you very much :).
  4. welsh alex
    welsh alex
    Oct 23, 2003
    50
    i have the same issue, would i need to buy one extra toslink cable or two?
    i.e. am i right in assuming if i have one toslink cable i would need one more for my new device and one to connect the switcher to the amp?
    im currently pulling my x box one in and out from the back of the amp when needed.
  5. tobyjuggler
    tobyjuggler
    Nov 4, 2004
    629
    Got one now...nice bit of kit, but yeah, you'll need at least three cables. One for each bit of equipment, plus one to go from the switch to your amp. It's a mechanical switch, but it sort of 'locks' into each position very neatly as you turn the switch.
  6. pcusack
    pcusack
    Jun 11, 2005
    24
    If i only knew.....
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    there is a unit made by "Audio Authority" that switches audio and video (component) on detection so worth a search has been duscussed here before but not cheap
