Quantcast
Two of the same webcams at the same time
deathtrap3000
I have two microsoft lifecam cinemas and im having trouble getting them both to work at the same time. They both work fine individually but whenever I try to get them to run at the same time either the program im using crashes or only one cam runs.
Has anyone had any luck getting two of the same webcams to work at the same time before?
namuk
the issue your having is the software or driver even both will not support two of the same cameras you really need to search a software that support multiple cams that's if yours is supported that is.
deathtrap3000
The software im using supports two cameras at the same time. Not sure about the drivers though. Is there something I can do like making a copy of the driver the two webcams are trying to use and tell one of them to use the copy?
cosmicma
if you have them one the same usb hub it might be a problem with drivers
just a thought..
