Two MCE2005 questions
Discussion in 'Microsoft Windows' started by hebawom, Mar 29, 2005.
  1. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    1. I want to use my HTPC exclusivley by the windows remote control. When I press the PC on/off button on the remote, it just puts it in standby, can I change this is shut the machine off?
    2. I notice that during a DVD that the lip-sync gets a tiny tiny bit out (miliseconds) would reclock help with this, and is it easy to use?
  2. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    Anyone? I only have one hour left at work to recieve any advice???
  3. lisag
    lisag
    Jul 14, 2004
    5,675
    Essex
    +332
    You can choose shut down as an option with the remote when exiting MCE
    Can you do a delay with your amp?
  4. cbemoore
    cbemoore
    May 16, 2002
    1,220
    38
    Eastleigh
    +16
    If you use MCE2005 as a TiVo-like PVR, its designed to be left on standby permanently and never switched off. If you have asked Media Center to record a TV programme or series, it will automatically wake up from standby when the recording is about to start, and revert to standby when the recording is finished. If you turn the PC off completely, the programmes won't be recorded!
    Chris
  5. gordonfmoore
    gordonfmoore
    If you aren't getting any options when you press the pc power button on the remote then you need to go to Control Panel|Power Options select the Advanced Tab and in the When I Press the Power button on my computer drop down, select the Ask me what to do option. This will then allow you to select Close mce, restart, shutdown or standby.
    Gordon
  6. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    Thankyou Gordon - that'll be the one
  7. Scotty
    Scotty
    Feb 12, 2002
    1,467
    Home Counties
    +412
    I you use the Nvidia DVD codecs this allows you to time delay the audio output thereby eliminating any lipsinc errors. :smashin:
  8. hebawom
    hebawom
    Apr 16, 2004
    187
    19
    Matlock
    That seems like a bit of a work-around. I wanted to sort of the cause of the problem, not the effects. Why does it slightly lose the sync? Is there a program that can constantly make sure the video and audio tracks are together? Thats why I was asking about ReClock?
