Two M1-DA into One
Discussion in 'Cables & Switches' started by JEDIBLADE, Aug 4, 2005.
  1. JEDIBLADE
    JEDIBLADE
    Sep 24, 2002
    1,613
    Sheffield
    +140
    I have an InFocus 4805 with an M1-DA conector on the rear. I have a Denon 1910 that outputs DVI and I also have a PC that output's VGA. I have the supplied Infocus adaptor that changes the VGA into M1-DA and a Lindy Adaptor that changes DVI into M1-DA. The problem is I only have one M1-DA connection ? Does anyone know if a company makes a two into one M1-DA switcher ? At the moment I have to change the lead when I want a different source.
  2. psflynn
    psflynn
    Nov 10, 2003
    346
    Swindon
    +5
    hi, i have a 4805 too. What dvi lead do u use?
