Zaid Amir
- Joined
- Feb 17, 2014
- Messages
- 3
- Reaction score
- 0
- Points
- 26
- Age
- 40
I need to find a way to have two satellite feeds go down one cable as I cannot add another cable (there is simply no room for it unless I demolish the house and re-build it). I found this Global Stacker De-Stacker (DiSEqC enabled) | Satbuyer which from the description shows that it gets the job done. However, one of my LNBs is a SatCR and the other one is a regular LNBF. Will I be able to use the stacker/de-stacker to merge the two signals into one cable. The length of the cable is about 12-15 meters and I need the SatCR because one of my receivers has the ability to view/record two channels at once while the other cable (from the regular LNB) will go to a different receiver.
Can someone help please?
(Link removed by admin )
