Two DVI output graphics card recommendation
Discussion in 'Desktop & Laptop Computers Forum' started by taimur, May 22, 2003.
  1. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    Are there any graphics cards that output on two DVI ports? Ideally, it would be possible to have two different outputs from each port. Also, how good are DVI to VGA converters? (eg this: http://www.thepcstore.co.uk/Graphics Cards/Mentor/GR1125.php)
    The reason I ask is that I have a PC with a CRT display at the moment. I plan to buy a plasma and LCD screen in the future, and upgrade my graphics card to cope with dual output for each screen.
    Taimur
  2. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Radeons dont allow different reolutions on each output so useless for what you want to do, the Matrox cards might be an option.
  3. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    what if I got an LCD monitor capable of displaying 1024x768 and a Pioneer 433MXE. Would it then be OK to get a Radeon, rather than a Matrox. I think the Matrox's tend to be a little more expensive at just over £200 whereas Radeon's are going for around just over £100.
    Taimur
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    I beleive that the Pioneer has a native res od 1024*768 so in that case a Radeon would pprobably give the better PQ for HTPC use and with both displays on the same resolution you have no problems.
    The latest radeon drivers (cat 3.4) allow the overlay to work on a cloned display for the 1st time so that suits this application perfectly.
  5. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
    Eh, yes they do. Have done for a couple of years now, at least.
    The Matrox Millennium P750 is probably worth a quick look as it has dual DVI output - quite expensive though. Perhaps the Millenium G550 (dual DVI version) is a better bet at about £100, but is overall not too hot in terms of specs. PowerColor were showing off a Radeon 9700 with dual DVI output a while back but nothing ever came of that. Again, that probably would have been too expensive.
    For ~£100 the G550 seems like your only option, although consider that if you can find a cheap PCI card with DVI output you can run two graphics cards in order to provide your two DVI outputs.
    MuFu.
  6. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    News to me, how do you do it then? :confused:
  7. MuFu
    MuFu
    Jul 24, 2002
    1,196
    41
    NW2, London
    +4
    You select a monitor from the drop-down menu in the Windows Display Properties app (=>Settings tab) and change the res. The other monitor shouldn't change if both are installed properly. You can also run independent refresh rates.
    I was running two LCDs at 1280x1024 and 1280x768 independently just recently (9700 Pro). In the past I've had two CRTs at 1280x960@85Hz and 1154x864@75Hz (8500LE) and a CRT and TV at 1280x960@85Hz and 848x480@60Hz respectively (HTPC - AIW 7500).
    I only think it works in extended desktop mode though - perhaps why you think otherwise. I believe some Matrox cards can go one step further and allow individual desktops, which I don't think is possible with nV or ATi solutions.
    :confused:
    MuFu.
  8. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    I'm still a bit confused - do the Radeon models have dual DVI outputs or are they one VGA and one DVI?
    Taimur
  9. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    I think all the ATI cards with adual output (ie not AIW) have 1 vga and 1 dvi.
  10. Kramer
    Kramer
    Yep, just 1x DVI & 1x VGA output incapable of independent resolutions (at the same time).
    Dual DVI outputs at individual resolutions would be ideal for me too - 1366x768 (HS10) & 1280x1024 (Hitachi LCD) - yummy, but not today :(
  11. tjcronin
    tjcronin
    Radeon cards CAN have differrent resolutions on two differrent display while displaying the windows desktop. I believe there is a problem when running 'clone' mode, where the displays have to be the same resolution. 'Clone' mode is where the second display is used to show a full-screen video.
