Two DV88 Plus's
Discussion in 'Arcam Owners' Forum' started by Clamicpo1, Aug 27, 2004.
  1. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,448
    Alvaston/Derby
    +265
    Hi, is it possible to run two of these side by side without the remotes interfering with each other.
    Charlie
  2. simoncope
    simoncope
    Yes.
    Take a piece of black insulation tape and stick it over the IR receiver window on one of the DVD players. Then only the 2nd player will respond to the remote control...
    Thank you and good night :rolleyes:
  3. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,448
    Alvaston/Derby
    +265
    Hi, I'll need to control both DVD players by remote.
    It looks like I'll have to look for another make to go with the Arcam I've already got.
    Charlie
  4. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    Over the Hill & Far Away
    +119
    yes maybe.. check out the setup menu where you can tell it the type of remote you are using.. maybe set it to different settings.. not sure if theres any major difference..worth a look ?
  5. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,448
    Alvaston/Derby
    +265
    It would be nice if it would work, is there anyone with two arcams out there who could try it.
    Charlie
  6. mjn
    mjn
    May 24, 2001
    18,377
    Herts, England
    +5,461
    have you given Arcam a ring?
  7. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,448
    Alvaston/Derby
    +265
    Sent an email, I'll just wait & see, hopefully they can help.
    Charlie
  8. Smurfin
    Smurfin
    Aug 13, 2002
    20,784
    +4,155
    Just curious, why do you want to run 2 of them?
  9. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,448
    Alvaston/Derby
    +265
    It takes me an age to get from where I watch a film to my wheelchair go change a disc then get back, it would be easier to have two DVD players & I like the Arcams.
    Charlie
  10. Smurfin
    Smurfin
    Aug 13, 2002
    20,784
    +4,155
    Good idea then:)
  11. mjn
    mjn
    May 24, 2001
    18,377
    Herts, England
    +5,461
    If most of your films are R1, why not import a 400 DVD jukebox?
    Cost around £400 inc shipping.
  12. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,448
    Alvaston/Derby
    +265
    Hi, all my DVD's are region 2 plus I like the picture quality from Arcam.
    Thanks for the suggestion.
    Charlie
  13. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,448
    Alvaston/Derby
    +265
    As I havent heard back from Arcam I'll assume you can't have two side by side. It looks like I may have to change to another make.
    Charlie
  14. brendank
    brendank
    Dec 13, 2003
    639
    drogheda, co louth,ireland
    +6
    hi charlie
    if arcam dont respond to your query these guys have the exact unit that you are looking for if you cant make out the stuff on the site just send michael an email explaining your situation and he will get back with a solution for you
    http://www.lintronic.dk
  15. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,448
    Alvaston/Derby
    +265
    If Arcam don't reply then I will not be buying another one of their DVD players but thanks for the help anyway.
    Charlie
  16. purifiedaudio
    purifiedaudio
    You can do this with a MX-3000 remote control and RF base station - it lets you use assign IR outputs so that you can control multiple units with one remote control.
    Somewhere in the Arcam IR document it talks about two different sets of IR codes for Arcam DVD players, I can't remember exactly what it was, but I think you can change codes that the 88 responds to. If you set one as IR set "a" and the other as "b" it may work. Again, I can't remember the details, but the Arcam guys should be able to sort this out (or they will determine that I am just confused).
    Good Luck
    Purified Audio
  17. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    The Home Theater Master MX-800 and MX-600 also support RF stations and they cost much less than the MX-3000.
    Dean
  18. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,448
    Alvaston/Derby
    +265
    I'll stick to using my Pronto's.
    Still waiting for Arcam to reply. It doesn't have to be an 88+, it could be a 27 or a 79 as long as I can use them both side by side. But if Arcam don't get back to me then I will have to look elsewhere.
    Charlie
  19. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    Hi Clamicpo1,
    You have a new personal message.
    Andrew
  20. Clamicpo1
    Clamicpo1
    Dec 12, 2002
    7,448
    Alvaston/Derby
    +265
    Thanks for the help Andy.
    Charlie
