Simple question but when you guys talk about a 2 channel amp this has 2 o/p's which will always be at the same volume,. source etc (even if that channel is not audible)? Yes? However I want an amp which controls the channels separately (eg at different volumes). Can I do this (at c £300/400 for the amp) or this called 2 amps? Peros
You do that through the preamp or you can use an amp with gain controls for each channel but that's not the best way to do it.
