Two center speakers?
Discussion in 'Home Cinema Speakers' started by AV nutter, Aug 26, 2006.
  1. AV nutter
    AV nutter
    :devil: My wifey thinks that old age has got the better of me or my illness in off again i truly belive now i have pj and the big picture i need two center speaker or the dialog gets lost also im getting out of storage to play with my othe pair of B AND W ASW 1000 just to liven up the room a bit.mike
  2. Mad Mr H
    Mad Mr H
    Jun 10, 2005
    4,460
    London
    +280
    Hi Mike,
    Often your processor with have a dialogue setting, which allows you to alter the level of speech.
    If not then I would suggest lowering the levels of you front left and right speakers.
    Your center ch if matched to the front left right should be fine.
    (I will aslo move this thread to the speaker section)
