Two budgets... but which systems?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Matthew Attoe, Dec 25, 2003.
  1. Matthew Attoe
    Matthew Attoe
    Dec 8, 2001
    695
    Norwich
    +11
    My wife wants to buy a new stereo, probably in the sales, consisting of CD player, amp, tuner (digital, preferably) and speakers. I already have some half-decent interconnects and speaker cable.The speakers will be placed against a wall on a laminate floor.
    She has a budget of around £500ish and is looking for a small-sized system (about the size of the TEAC Reference 500, which she likes already). Would systems would you recommend we look at.
    Now, if i were to boost the budget to about £1,000, what should we be looking at?
    I appreciate that the equipment needs listening too, but we just need some pointers on where to start.
    What on-line retailers would you recommend, as this may well make her/our money go further.
    Merry christmas,
    Matthew
  2. rupbert
    rupbert
    Jun 24, 2002
    544
    +18
    Hey matthew,
    Get a copy of January's What Hi-Fi where they have looked at music systems built using same brand seperates, on varying budgets...
    The Cambridge Audio system came top, which consisted off:
    Cambridge Azur 640c CD player £250 (Richer Sounds)
    Cambridge Azur 640a amplifier £250 (Richer Sounds)
    Monitor Audio Bronze B2 speakers £180 (HiFiBlitz)
    Comes to £680. If you want to save £100, you can get the 540c/540a versions of the above...
    Then you can add the award winning Cambridge DAB500 digital tuner £150 (Richer Sounds). Or if you listen to the radio regularily then try the highly praised Pure Digital DRX-701 £190 (empiredirect)
    The new Azur range is beautiful (so it will please the wife), as are the B2's...
    All three online dealers I have mentioned are very well known. I personally buy everything from EmpireDirect, and get some stuff from Richer Sounds while out shopping.
    If you have a local Richer Sounds, ask them for a demo of the above.
  3. Matthew Attoe
    Matthew Attoe
    Dec 8, 2001
    695
    Norwich
    +11
    Thanks for taking the time to reply. I appreciate it.
    Believe it or not, I did buy the what Hi-fi issue you mention, and will certainly be checking the Azur range.
    I have a Richer Sounds and a Sevenoaks in the city, as well as an independent supplier, so we will be certainly be checking them out.
    Again, thanks for replying,
    Matthew
  4. rupbert
    rupbert
    Jun 24, 2002
    544
    +18
    Your welcome :)
  5. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,501
    Edinburgh
    +1,237
    If you are looking for somehting fairly discrete then you can pick up a Linn Classik from Sevenoaks for £750. Partnered with the Quad 11Ls it sounds great.
