Twin Subs?
Discussion in 'Subwoofers' started by Johndm, Apr 27, 2003.
  1. Johndm
    Johndm
    Jan 25, 2003
    1,816
    Bedford UK
    +57
    Thinking of adding a second sub to my VA555ES, as it has outputs for two. (If you have sockets, you gotta use em eh?)
    Couple of questions,
    Are two really worthwhile?
    Would the phase setting on subs need to be opposite, ie one to 0 and one to 180?
    regards
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    Not being rude but one better quality subwoofer would be far more beneficial than another Gale.
  3. Johndm
    Johndm
    Jan 25, 2003
    1,816
    Bedford UK
    +57
    Did I say it would be twin Gales.......I am aware that the sub I currently use is of fairly low quality. The question is about two subs in general..:D
  4. nathan_silly
    nathan_silly
    Two Rel Studios III, two SVS SS's or PB4+, or two Velodyne HGS-18's... hmmm :)
    Might need a phase adjustment though (unless placing behind the L & R speakers)
    I'll probably get a single SVS CS-Ultra with a high powered two channel poweramp- easy just to add another one. Just connect speaker cable to the poweramp, and place..
  5. dts_boy
    dts_boy
    Nov 26, 2001
    2,544
    Manchester suburbs...
    +145
    its much moe difficult integrating two subs into a sytem than one, one can be hard enough at times! i would say buy a single, better quality sub to start with and i suspect you will be just as happy:smoke:
  6. nathan_silly
    nathan_silly
    I wondering about the BFD Pro. Does it have a one button wizard thingy which does everything for you? (by placing a SPL meter into it- it'll sort out the peaks and troughs automatically)
    Doing it manually seems a daunting task.
  7. bob007
    bob007
    Have a word with Taz, he has a thread going here in General Chat that might be of help. ;)
    [EDIT] Sorry, disregard my post, thought you were on about Twin Tubs. :suicide: :D
  8. nathan_silly
    nathan_silly
    No jokes regarding women sitting on washing machines whilst in spin cycle please..
    oops! :)
    Hmm could be a alternatice to Buttkickers!
  9. Johndm
    Johndm
    Jan 25, 2003
    1,816
    Bedford UK
    +57
    So how do I connect two NORFROST VELO AC2000 2800 RPM POLAR machines to my VA555ES (bearing in mind that they will sound better than my one Gale 3080)
  10. DSM
    DSM
    Jun 14, 2002
    85
    West Wales
    Yes 2 subs are better than 1, I have 2 servo 15's which are great!
    Like driving a V8 car - cruising at high speed and not thrashing like a straight 4! But make sure everything is bolted down!
    Good luck,
    Dave
  11. NicolasB
    NicolasB
    Oct 3, 2002
    6,070
    Emily's Shop
    +669
    If properly set up, two subs fed the same signal will generate the same volume level as a single sub but with a bit less distortion, which is a good thing - but they can be a real pig to set up.
    I don't know quite how the bass management works on the STRVA555. Some high-end products (Meridian and Lexicon, notably) have multiple subwoofer outputs that actually produce different signals - for example separating bass from the left speakers and bass from the right speakers, so you get your bass in stereo. If your hardware does this then it's probably worth experimenting with.
  12. Johndm
    Johndm
    Jan 25, 2003
    1,816
    Bedford UK
    +57
    The manual says..'You can connect an active subwoofer to either jacks. The remaining jack can be used to connect a second'
    Plenty of info from Sony there then! Would guess theres no difference in output from either jack unless someone knows better??
