Twin help needed
Discussion in 'Digital TV & Video Players & Recorders' started by Ged, Jun 1, 2004.
Tags:
  1. Ged
    Ged
    Apr 29, 2002
    925
    +17
    I have just bought one and I am having problems recording and a search is not bringing much up to help.
    I plugged it in, did the install and messed with the guide etc, pretty much like most boxes. I then recorded some snippets, the first one stopped due to no signal (aerial fine), second stuttered on play back, after this if I press record and return to the library I am faced with a cannot play message.
    I have had it show the Pace screen, only show Ch 5. and "inlt".
    Done the initialise disc and reset thing and it will not play the recording program and stops it when going to the library.
    Any help to prevent a return appreciated.
    I assume you can press record whilst a program is on and not have to go through the timer/guide?
    Ged
  2. AOD
    AOD
    Feb 7, 2001
    710
    London
    +4
    I would imagine that your new box has an older flakier version of the firmware onboard.
    The next update for the Twin is due on 5th June, you'll need to leave your box tuned to a BBC channel overnight and it should automatically pick up the update.
    If it still doesn't play ball after this, then I'd have a word with your retailer.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,844
    Somewhere in South Yorkshire
    +5,078
    Easy way to see if it has the original (buggy) software:
    Does text work?
    No = original software
    Yes = a revised version
    We have high hopes for the June release - it has been a long time coming. Hopefully this is indicative of an extended development testing and bugfix cycle.
    As already mentioned - you need to be tuned in and swtched on to a BBC channel on the broadcast date. I assume that you get clean reception on e.g. BBC1??
  4. Ged
    Ged
    Apr 29, 2002
    925
    +17
    Thanks for the info, yes it has the origional software and I will leave it on Saturday morning. I phoned the retailer and they will also swop it it Saturday for a new one, is this level of poor quality to expected in none upgraded Twins or is it hit and miss?
    I am unsure as to whether I should just exchange it anyway so any ideas welcome and have many people seen theirs improve after the upgrade?
    Regards
    Ged
  5. LV426
    LV426
    Jul 14, 2000
    12,844
    +5,078
    Oh yes.....previous upgrades (the October one, repeated several times since) made a huge difference.....
    This is almost certainly NOT a hardware issue; I recommend you wait until after a satisfactory update, before troubling your retailer.
  6. Ged
    Ged
    Apr 29, 2002
    925
    +17
    Thanks for the reassurance Nigel.
  7. CD3660
    CD3660
    Jun 11, 2004
    34
    Cheshire
    Nigel, I missed the software upgrade earlier this week - any idea when it will be repeated?
  8. LV426
    LV426
    Jul 14, 2000
    12,844
    +5,078
    You can keep an eye on two places:
    pacefreetoview.co.uk/02ee.asp
    (Pace don't like people linking to their website, so type it in prefixed with www.)
    and
    www.dtg.org.uk ..... on the menu: Retailer/Installer > Engineering channel download schedule
  9. CD3660
    CD3660
    Jun 11, 2004
    34
    Cheshire
    Nigel, many thanks for the swift reply
