Tweaking PB TV-100
Discussion in 'Desktop & Laptop Computers Forum' started by carrolls, Jan 9, 2004.
  1. carrolls
    carrolls
    It seems the max definition I can get from the PB TV-100 is
    640 x 480.
    in the manual it specifies 720x576. How do I tweak the PC to make this option appear in the FlyVideo software?.
    I have a Pentium 4 2.66 and an ASUS 800 MB with 512MB RAM.
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Hi and welcome to the forums!
    First of all download the excellent DScaler (download 4.18) which will give you much better results. Searching the forums for "TV100" will give you lots of info on the card and using it with DScaler. DScaler will display at whatever your desktop resolution is.
  3. carrolls
    carrolls
    Thanks rct, I have done just that and the picture is just A1.
    Just one thing. When I try to record using the various codecs and compression formats, thre is only about two or three frames recorded per second and the picture is very jumpy.
    Is there any suggestions on how to get a reasonably high-definition compressed recording (Video CD quality) without using up all my hard drive space? (120 GB)
