TW7400 with amazon fire stick
soundchip
Got a Epson TW7400 projector and want to use an Amazon fire stick with it, only the TW7400 doesn't have a sound output.
How do I go about getting sound from the fire stick?
I don't have an AV amp either, and instead are using the projector with a Humax box so taking a phono connection from this into the NAD amp
Can anyone suggest some ways (or by use of an adaptor) of doing this please?
next010
Get a 4K 60Hz switch with audio extractor built in like this, it has RCA phono audio outputs.
Plug the video out from the switch into the projector and audio into your speakers, you can put the FireTV and Humax on the switch video inputs.
Joe Fernand
AVForums Sponsor
Source > HDMI Extractor > Projector+HiFi Amp is the way to go - though be aware you can run into 'lip sync' issues as the video processing is usually slower than the audio processing.
Joe
soundchip
Hi Next010,
Cheers for this, looks good.
Found an updated version of this box here, I'm guessing this will do the same?, and it seems cheaper!
Amazon product
Joe Fernand
AVForums Sponsor
The Switch you link to indicates HDCP 1.4 - which means it is not compatible with the majority of 4K UHD Source devices which require HDCP 2.2.
Joe
soundchip
Just so your aware I've done this, and tested with 2 different HDMI switch boxes with RCA out. I get a picture fine, but no sound. I've also disconnected everything else to make sure. Someone did say that this is because there is no speaker output on the tw7400, but surely this is the switches job to extract the audio for you. I cant believe it's this difficult to do!
Joe Fernand
AVForums Sponsor
You will need to ensure the Source is set to Output 2.0 PCM and ideally the Switch has user adjustable EDID which includes audio settings.
Joe
soundchip
Cheers Joe for your advice.
Do you have any link suggestions on a switch to test out? - say from amazon or another supplier.
