Lukeymac
Established Member
Suddenly went from working one day to when being turned on flashing a red light once every second (according to the manual this means an internal error and it should be sent back). However after trying the next day all was working fine. Then this afternoon I encountered the same problems - it switches on, the lamp doesn't fire up and the red light starts flashing once every second. After retring several times from unplugging and replugging the power lead after a short pause it starts working again. The only thing I can think of is that it's actually a heat dispersion problem as it is house in a box unit - although it has what I thought would be enough ventilation around it. The filter is clean and the lamp is only 50 odd hours old. Only other possibly slightly strange thing about the setup in that the projection is at an angle when it is pointing down and not up - i.e. raised at the back but on a shelf and not ceiling mounted. If anyone have any ideas or encountered something similar I'd like to know please
. Cheers in advance
