TW100 using DVI - Help needed
Discussion in 'Desktop & Laptop Computers Forum' started by nelson, Aug 18, 2002.
  1. nelson
    nelson
    May 19, 2002
    102
    Nr Coventry, UK
    +6
    I have tried using my TW100 with HCPC: ATI Radeon 7500, DVI-I, Powerstrip, but the picture is terrible. I need help with what I might be doing wrong?
    The picture is blurry, noisy, poor colour and it is not displaying the full image.
    The powerstrip settings are as posted by someone as being the 'official Epson settings':
    Pixel Clock 74.176MHz (74.085)
    Horizontal:
    · Scan Rate 44.955KHz (44.954)
    · Active pixels 1280 pixels
    · Front porch pixels 70 pixels
    · Sync width pixels 80 pixels
    · Back porch pixels 220 pixels (218)
    · Total pixels 1650 pixels (1648)
    Vertical:
    · Refresh Rate 59.940Hz (59.939)
    · Active lines 720 lines
    · Front porch lines 5 lines
    · Sync width lines 5 lines
    · Back porch lines 20 lines
    · Total lines 750 lines
    Please note that the figures indicated within ( ) are the closest matches I can get Powerstrip to accept without messing up all the other values.
    Can anyone who is successfully using the DVI input please confirm their own settings so that I can compare.
    :confused:
  2. jrwood
    jrwood
    I think you need the latest firmware patch for native pixel mapping on the DVI input. However I think these settings are meant to give a good picture so try them out.
    DVI
    Horizonal:
    Active pixels 1280
    Refresh rate 60K
    Front porch 80
    Sync width 136
    Back porch 216
    Polarity Positive
    Vertical:
    Active pixels 960
    Refresh rate 60
    Front porch 1
    Sync width 3
    Back porch 30
    Polarity Positive
    Pixel clock 102.104
    or for native VGA pixel mapping which should? bypass the internal scaler..
    VGA
    Horizontal
    Active 1280
    Front porch 103
    Sync width 128
    Back porch 289
    Total 1800
    Scan rate 56.746 kHz
    Vertical
    Active 720
    Front porch 121
    Sync width 3
    Back porch 150
    Total 994
    Refresh rate 57.089
    Pixel clock 102.104
    with TW100 settings / Tracking 0 / Sync. 16
    So either use the DVI input with the scaler kicking in, or the vga input bypassing the scaler (if these settings work!)...otherwise wait for the firmware fix from epson.
    /James
