TW100 using DVI - Help needed
Discussion in 'Projectors, Screens & Video Processors' started by nelson, Aug 18, 2002.
  1. nelson
    nelson
    May 19, 2002
    102
    Nr Coventry, UK
    +6
    I have tried using my TW100 with HCPC: ATI Radeon 7500, DVI-I, Powerstrip, but the picture is terrible. I need help with what I might be doing wrong?
    The picture is blurry, noisy, poor colour and it is not displaying the full image.
    The powerstrip settings are as posted by someone as being the 'official Epson settings':
    Pixel Clock 74.176MHz (74.085)
    Horizontal:
    · Scan Rate 44.955KHz (44.954)
    · Active pixels 1280 pixels
    · Front porch pixels 70 pixels
    · Sync width pixels 80 pixels
    · Back porch pixels 220 pixels (218)
    · Total pixels 1650 pixels (1648)
    Vertical:
    · Refresh Rate 59.940Hz (59.939)
    · Active lines 720 lines
    · Front porch lines 5 lines
    · Sync width lines 5 lines
    · Back porch lines 20 lines
    · Total lines 750 lines
    Please note that the figures indicated within ( ) are the closest matches I can get Powerstrip to accept without messing up all the other values.
    Can anyone who is successfully using the DVI input please confirm their own settings so that I can compare.
    :confused:
  2. MerMan
    MerMan
    Mar 31, 2002
    146
    16
    Nelson
    Have you been able to use the DVI port at any resolution?
  3. nelson
    nelson
    May 19, 2002
    102
    Nr Coventry, UK
    +6
    I've only tried it using the settings I listed so far as these were supposed to be the settings recommended by Epson (I think it was Kane Williams that got hold of the figures initially).
    There must be something that I haven't configured correctly somewhere, either in Powerstrip or the settings for the graphics card.
    P.S. I'll also post this in the HCPC section.
  4. MerMan
    MerMan
    Mar 31, 2002
    146
    16
    When I had the projector on demo (v1.02) I tried the following which worked very well.
    Use resolution 1280x960 (I didnt make any modifications to powerstrip). Then when viewing use ZOOM mode.
    I think it was Gearhead who told me to try this. It worked very well.
    See if you can get that working.
  5. nelson
    nelson
    May 19, 2002
    102
    Nr Coventry, UK
    +6
    Ok thanks, I'll give that a try and report back later on (may be tomorrow).
  6. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    MerMan
    PM sent.
  7. Guest
    Those powerstrip settings you posted are only valid for analogue signals, as these are required by the RAMDAC (which is the part you're programming with powerstrip).
  8. nelson
    nelson
    May 19, 2002
    102
    Nr Coventry, UK
    +6
    Thanks for the comments everyone.
    One important point I forgot to mention in my post was that I am using the latest firmware 1.08 and Through Mode.
    I have tried again and now get a proper image. This time I just selected the default Powerstrip setting '1280 x 720 LCD Panel (16:9)' and the TW100 was able to synch and display correctly. It reports that it is seeing a digital signal.
    I hadn't realised that the settings various people had quoted in earlier posts only applied to analog on the DVI input.
    I saw somewhere (but can't find the post again) that it is possible to set the Radeon 7500 to output digital signals only on DVI-I. Anyone know how to do this, I can't see a setting for it anywhere?
    I will reserve judgement on the quality of the image from DVI input until I have spent a bit more time playing around with it. First impression though, is that it doesn't appear to be much different to what I see using my Toshiba SD510E DVD Player and Progressive Scan Component outputs. I'll let you know how I get on.
    By the way, this is my first projector. I spent nearly two years looking around before I saw something that I felt was good enough to spend my money on. I just love this projector!:D
  9. MerMan
    MerMan
    Mar 31, 2002
    146
    16
    Nelson
    You have a PM.
    Regards
