Does anyone know where you can get a copy of the softwrae to control the TW100 from a PC?
M MerMan Standard Member Sep 1, 2002 #1 Does anyone know where you can get a copy of the softwrae to control the TW100 from a PC?
Guest Nov 7, 2002 #2 Yes, I do, I have it, send me an private email at [email protected] and I will email it to you... Erick Otto
L LordX Guest Nov 8, 2002 #3 You can find some software and information at these addresses: emplink21l version 1.0: Doesn't support TW100. emplink21l version 1.1: Should support TW100 according to Epson Bulletin. ESC/VP 21 Communication Manual: TW100 should support some of these commands according to the User's Guide. I haven't had much luck though. I cannot for example change user logo even though it should be supported according to the User's Guide (?). EmuMannen tried several VP21 commands with various result.
Guest Nov 9, 2002 #4 Lordx, excellent digging I ahve uploaded all of these files to the yahoogroups i have created for just TW100 http://www.yahoogroups.com/group/tw100 Erick
