onedrift
I am looking to get a 65 inch LED TV but I'm finding quite a few of them have issues with vertical banding / grey screen effect.
I bought the LG 65SJ810V but there are two very visible vertical lines down the screen when the background image is the same colour. This is particularly noticeable when watching football (as screen is mostly green and same colour) and is very distracting. We have tried changing settings, turning on/off local dimming etc but it doesn't fix it.
We were told we could get a replacement but from reading online I'm worried a replacement will have the same issue.
Can anyone recommend a 65 inch which doesn't have this issue? Or is it the luck of the draw? Football is watched a lot at our home so it's quite important the TV doesn't have vertical banding as it just makes the image look dirty and is too distracting.
Many thanks!
Many thanks!
