TV's: Is it possible to access video stored on local network?
whimsical
Hello,
Not sure if this is "smart TV" functionality or not (obviously I havent got one yet and I'm a bit in the dark regarding all the gadgets). I'm soon to start rewiring my home (data/satellite/electric etc) and was wondering about future proofing connectivity.
Is it possible to access files on a PC/server/nas via a smart TV? I was contemplating copying over the dvd collection to a shared network hard drive for convenience. Not sure if this is possible
If so, what sort of connection would I be looking at? Would it work via ethernet or would it be USB?
AngelEyes
I am not up on Smart TV tech but my guess is that you probably can't or if you can it is limited.
You can use something like a Dune or Popcorn Hour to do this though. I have owned both and would highly recommend a Dune running Yadis, depending on the model you buy it would replace your DVD/Bluray player and also be able to access any networked media via a very nice 'media wall' interface with all movie imagery and data scraped from the net.
I have a 20Tb unRaid server located in my office allowing access from multiple locations (Dune Players) around the house via Ethernet. If you are running cables I recommend Cat6 and use decent cable and terminate it well.
Adam :)
davepuma
It obviously depends on the TV. One thing I have found though is the format support isn't as flexible as a dedicated streaming device. I don't have a SMART TV but friends do and they can access content from NAS etc. over ethernet and a hard drive connected via USB.
Obviously you could add a streaming device as above e.g. appleTV, wdtv, popcorn hour, boxee box or a small PC. There are a few people that have installed XBMC for example on those Raspberry pi machines and there are small devices that run Android that could be hooked up. The streaming devices forum and obviously TV forums are your best bet. I use a home built PC as my living room HCPC and an Acer Revo (set to wake on Lan) in a second room.
If I could start again, I would love to run cat6 all over the house.
Curly99
Yes, dependent on what formats the TV excepts though there is server software that helps, I have Twonky on my WD world book, Serviio media server gets recommended a lot in the TV forums, USB I'm not so sure about but it should allow you to play say a film copied to a USB memory stick...
Curly
whimsical
Many many thanks for the advice folks. Certainly points me in the right direction and gives me a number of options.
Thanks once again
Vince:)
