tvlink, freeview and analogue tv over one coax ?
Discussion in 'Freeview & YouView' started by ebony, Oct 19, 2005.
  1. ebony
    ebony
    Feb 11, 2005
    159
    +5
    I have sky downstairs connected to a freeview equipped tv.
    I have a single coax cable running up to the loft and down into the bedroom tv with tvlink connected.
    This gives me sky upstairs with no issues.
    In the loft I now have two aerial connections doing nothing.
    Can I use any sort of device so I can get freeview on the TV downstairs and normal analogue tv upstairs whilst still maintaing th sky tvlink connection, and all with the single coax from downstairs to the loft ?
    Thanks.
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    For Freeview buy a box for the upstairs TV - easiest and cheapest answer
  3. ebony
    ebony
    Feb 11, 2005
    159
    +5
    I appreciate the quick response, and that would be the easiest way....
    however the likely scenario is that the wife will want to watch sky+ upstairs ( whatever garbage shes taped ), and I will want to watch a different channel downstairs, which would normally be anything available on freeview ( i.e. no sky sports or movies required ).
    So ideally I want to be able to feed downstairs from an aerial whilst a feed from the sky goes upstairs along the same cable..... I guess I know the answer already is to start laying some more cable !!!
