TVix M-4000P Music and movie handling
Discussion in 'Desktop & Laptop Computers Forum' started by supo, Jan 1, 2007.
  1. supo
    supo
    Feb 10, 2005
    142
    16
    I am interested in this product, mainly fro music storage and plaback, and then secondly movies and photos.
    Can you select tracks by genree, artists, etc
    Can you create a playlist while listenoning to music without stopping the music first?
    How brilliant and clear is the user interface? Is it attractive?
    Can you connect a freeview tuner to it and then record of it.
    In short I am looking for all the functionality of archos media player series (ie archos av500, archos av504, av604 etc) without added benefit of HD playing.
    Happy new year to all.
    bold99
  2. timgoff
    timgoff
    Bold99
    Did you buy at 4000P in the end? I'm considering buying one myself
    Tim
  3. Elvis
    Elvis
    In Answer to your questions:
    Q: Can you select tracks by genree, artists, etc
    A: No
    Q: Can you create a playlist while listenoning to music without stopping the music first?
    A: No
    Q: How brilliant and clear is the user interface? Is it attractive?
    A: GUI is 'functional' certainly not pretty but adequate.
    Q: Can you connect a freeview tuner to it and then record of it.
    A: No, [-]although there may be an add-on available to enable this.[/-] Not on the 4000P model
    Playback from internal HDD is good and it works with loads of codecs. Supports HD content and has good range of connections on the back (sVideo, Component, composite, DVI, optical audio). Personally I'm having lots of problems with network features such as NFS/Samba network streaming and FTP access. If you don't need network access it's great, if you do then you may have problems like me, although many seem not to.
  4. sloshed
    sloshed
    Jul 17, 2006
    5
    How do you select tracks if not by artist ?
    Apologies if this appears, a stupid question.
    Many thanks.
  5. Elvis
    Elvis
    Tracks are listed by filename. You could incorporate the artist into the file name I suppose. Alternatively you could place tracks in a series of folders named by artist. It doesn't have the functionality of something like iTunes though.
