TVIX 6500A WI-FI Help
Discussion in 'Video Streaming Boxes & Services' started by DaveH, Feb 4, 2009.
  1. DaveH
    DaveH
    Aug 1, 2000
    771
    28
    Surbiton, Surrey
    +41
    Hi all,
    Got one of these units yesterday and think it is great!
    The only problem is I cannot get wireless to work.
    I have the Linksys approved adaptor.
    I can successfully find my BeBox modem (It's red meaning it's supported) when I search for an Access Point.
    If I use DHCP, all the fields are missing except BeBox name and Mac Address.
    So I choose Static IP and input my details according to the unhelpful broken English manual.
    I have Netshare running and setup on my PC and have created the shares with the IP address of my server (PC) yet when I ping it fails. I also cannot get to the share to display the files.
    I realise this is hard to describe without showing my IP addresses and I can certainly do that if posting an ip beginning 192. is okay.
    Anyone any ideas?
  2. DaveH
    DaveH
    Aug 1, 2000
    771
    28
    Surbiton, Surrey
    +41
    Sorted it!
    My modem was not set for WEP 64. Its working but chugging badly.
    Firewall issue or bad hardware or just normal?
  3. DaveH
    DaveH
    Aug 1, 2000
    771
    28
    Surbiton, Surrey
    +41
    Ok, if I turn my fireall off which is Sygate Personal Firewall. It runs perfectly, smooth as silk when streaming content.
    But with the firewall on, only on streaming it chugs and freezes. A check of the security log in Sygate says something about critical problem with the IP Packets unable to be assembled.
    I tried to setup a rule allowing all traffic on the TVix IP address but not luck,
    Any advice people? I don't want to leave my firewall off really...
    Thanks.
