TVersity help needed
Discussion in 'Xbox Forums' started by leamspaceman, Jan 4, 2007.
  1. leamspaceman
    leamspaceman
    Jun 22, 2004
    7,800
    +4,297
    I've installed TVersity but am struggling with getting anything to play on my 360 though. Any help anyone can offer is greatly appreciated.
    My 360 has picked up my PC and is showing it as 'TVersity on Pegasus-Ti.' I can see how to navigate to a file or folder on TVersity and have added my music folder from my external hard drive. However, none of the songs show up on my 360? I've tried disabling Zone Alarm firewall as that was a problem with WMP 11, but still nothing.
    How do I get files/folders on my PC to show up on the 360 with TVersity?
    Thanks in advance.
  2. Guns_LotsOfGuns
    Guns_LotsOfGuns
    Moderator/Games Reviewer
    Jul 19, 2006
    8,179
    Tumbling down the rabbit hole
    +3,312
  3. leamspaceman
    leamspaceman
    Jun 22, 2004
    7,800
    +4,297
    Yes, I've read through it a few times but I'm still stuck. I just cannot get the 360 to see files/folders I add to TVersity. My 360 is seeing my PC okay but that's it.
  4. Br0ken
    Br0ken
    Jun 13, 2006
    10,469
    localhost
    +1,314
    How have you added your files to Tversity's library?
  5. lazymatt
    lazymatt
    Oct 23, 2006
    1,999
    Croydon
    +188
    I know this sounds silly, but once you've added your music files to TVersiy, have you waited for the spinning disc in the top right to stop spinning?
    Your 360 won't be able to see any files until TVersity has fully updated it's library with all your files, which can take ages.
  6. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    You need to first Index your music if you use TVersiy and the second tab after a wile you will see your albums count going up.
    Try - http://localhost:41952/flashlib this will also show you your indexed files.
  7. leamspaceman
    leamspaceman
    Jun 22, 2004
    7,800
    +4,297
    That was one of the problems...so thanks for that.
    Before that however, I switched my 360 off and on a few times and after about the third attempt it started to 'see' the files I'd added to TVersity. I've found since that the 360 seems to be somewhat temperamental in whether or not it'll connect to my PC. It sees that I'm connected to my PC via TVersity and I do the 'test connection' and it all comes up fine but it wont 'see' the PC and the files. If I turn the 360 off and on again a few times it finally sees it.
    Strange.
    The TVersity software is very good. It plays ALL my music/pictures/video so far. Haven't had to install anything other than TVersity for this to be the case.
    This is great software, just not sure why my 360 isn't seeing the PC so much.
    Cheers for the input guys...fantastic help:thumbsup: :thumbsup: :thumbsup:
  8. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    You said that you use Zonealarms ? what level of security have you set it on ? Is the 360 in the trusted or Internet zone?
  9. leamspaceman
    leamspaceman
    Jun 22, 2004
    7,800
    +4,297
    I dont know...how do I check that and change it?
    What 'zone' should it be in?
    I notice that under 'program control' TVersity is listed and in the 'Access' column it has green ticks under 'Trusted' and 'Internet.' In the 'Server' column it has blue question marks under 'Trusted' and 'Internet.'
    I cant see anything for the 360 itself.
    My 'Internet Zone' security is set to 'High' and my 'Trusted Zone' security is set to 'Medium.'
    What do I need to do?
  10. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    Everything seems fine....
    I think you need to do the same as me. You need to learn how to open a port in zonealarms.
    This is from the top of my head as I dont have it in from of me. If you go into the firewall section you will see the two zones. Click on customise on the Trusted section. Now you should see a list of allowed and blocked ports. In the allowed ports click on inbound UDP and Outbound and then do the same for TCP. Add the following:
    UPnP TCP/ports 2869 and 5000
    UPnP UDP/ port 1900
    TVersity TCP port 41952
    After this apply the rules click on apply and then run TVersity and make sure that the server is running also. You should not see a red icon in the bottom of the task bar it should be blue.
    Hope this helps. :smashin:
  11. maverik1979
    maverik1979
    May 27, 2006
    84
    +5
    just a quick question, you have enabled file sharing on the folder you are using for your music ?
  12. leamspaceman
    leamspaceman
    Jun 22, 2004
    7,800
    +4,297
    I haven't done that specifically. However, my music/videos/pics stream perfectly to my 360...when the 360 'sees' my PC. That's the only intermittent problem I have right now.
    Am gonna try pixels suggestion and see how things go.
  13. leamspaceman
    leamspaceman
    Jun 22, 2004
    7,800
    +4,297
    Thanks for that.
    I dont have the 'customise' option, probably cos I'm running Zone Alarm free edition. However, the icon is always blue when the server is running...it's never red.
    I think my 360 is just temperamental in picking up my PC. Could be down to positioning. I'll see how it goes over the next few days.
    Update: Just switched on my 360 and it connected with my PC immediately. Maybe it was just teething problems?
