Tvdrive ?
Discussion in 'Cable TV & Virgin Media TV' started by jb57uk, Dec 24, 2006.
  1. jb57uk
    jb57uk
    Nov 27, 2006
    12
    3
    Hi Need some help if possible,
    Got the new Ntl tvdrive friday, the remote does not operate the
    volume _ + or the mute on my telly LG42PC1D,,does any one have the codes for my make of tv ? thanks,,
    :lease:
  2. TheFreeJaffa
    TheFreeJaffa
    Dec 7, 2006
    515
    46
    Coventry
    +109
    On your Tv Drive remote, press Home >> 'Help and Info' >>> 'Remote Control'. You can then display a list of codes for several makes of TV. Once you have the code, you can then follow the on screen instructions to enter the code which will allow you to change the volume from the TV Drive remote.
  3. jb57uk
    jb57uk
    Nov 27, 2006
    12
    3
    Hi chris , list does not supply codes for LG,,,
  4. TheFreeJaffa
    TheFreeJaffa
    Dec 7, 2006
    515
    46
    Coventry
    +109
    Sorry, don't know codes for LG. But someone out there must know... :confused:
