silverpuma
Hi, I'm looking to find out if I can add manually the settings for TV3 an Republic of Ireland TV channel to my Sky+ setup, I'm in Northern Ireland and have been able to get as standard on my Sky, RTE 1 & 2 and TG4, all channels based in the Republic of Ireland.
I have searched this forum and read the thread http://www.avforums.com/forums/showthread.php?t=477080&highlight=tv3
But it doesn't help me...I think....but....I could be missing something really simple, not the first time that's happened
To explain; When I go to my "system setup" > "add channels" I get the following info on screen:
Freq (GHZ)........................11.778
Pol....................................V
Symbol rate (Mband)............27.5
FEC....................................2/3
I can change all the setting except the Freq 11.778 This is my problem , when I go to http://www.satcodx2.com/0282/eng/ as advised by the post mentioned above I can't find a 11.778 GHZ range. I can only find the TV3 listed under 10.744 GHZ, but since I can't change my Freq (GHZ) from the 11.778 that's showing as default I presume I can't then tune in manually TV3 as its on 10.744? Is this correct
I really an just trying to muddle through this as best I can as a complete Freq/Fec etc novice so any advice or help would be really appreciated.........
I hope this all makes sense to someone
