TV100 Card Drivers for XP needed
Discussion in 'Desktop & Laptop Computers Forum' started by Mark Ward, Jul 8, 2004.
  1. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,796
    41
    Kent
    +18
    Having done a complete re-install I find that I can no longer get my TV100 card from PC World that I use with DScaler to install.
    I remember it was a FlyVideo driver that was used but the version I have seems only to install some TV software and not the card drivers.
    Can anyone point me in the direction of the specific drivers I need to find for this card under XP please?
    Many thanks,
    Mark.
  2. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
  3. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    It also works with dscaler with no drivers.
  4. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,796
    41
    Kent
    +18
    Thanks Jeff & John.
    It seems like that isn't the right driver for my card. I stillhave an unknown "multimedia device" requring a driver. Even though D-Scaler will work without I#d still rather get the thing properly installed.
    I'll keep searching.
    Thanks,
    MArk.
  5. andy572
    andy572
    Dec 4, 2002
    361
    Oop North
    This support page might help you, Mark.
    If you are using DirectX 9.0b and haven't done so, don't forget to also download the MS 'tuner hotfix' from here.
    Good luck :smashin:
  6. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    I've got the driver on a disk somewhere, I'll mail it to you.
  7. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,796
    41
    Kent
    +18
    @ Andy
    Yeas I had installed that patch, no success.
    @ John
    Don't worry about sending me the disc, I do have a copy, it just doesn't seem to work with my card.
    Further investigation show that my Nebula Card also won't install.
    This has to be something to do with the PCI bus and overclocking. I haven't a clue how to set my A7N8X up to fix the PCI bus, I don't actually think it's possible.
    I'll keep trying though as I need the extra speed from the CPU:)
    Cheers,
    Mark.
