TV with 2 RGB scart inputs
Discussion in 'General TV Discussions Forum' started by pmladeira, Dec 12, 2002.
  1. pmladeira
    pmladeira
    Oct 31, 2002
    45
    Does anyone know if there are TV with more than one RGB scart input ?
    I want to connect a PS2 and a DVD, both with a RGB scart lead but don't want to start connecting, disconnectiong every time I want to use one of them.
  2. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
  3. Greekman
    Greekman
    SONY FQ80. Check it out though...
  4. pmladeira
    pmladeira
    Oct 31, 2002
    45
    And if a use a DVD player which has one input scart ? Would I loose some quality compared to connecting directly to the TV.
    I'm after a DVD player and noticed the Pioneer 656-A has two scarts. Would this be a good solution ?
  5. philinman
    philinman
    Jul 6, 2002
    408
    shropshire
    +4
    Hi i have a sony DVPNS 7000 ( i think thats right) dvd player and it has 2 scarts on it so i connect my Sky Digital through my DVD player and this gives me the option of which source to use .
    with the dvd player it takes the lead turn off the dvd player and it allows Sky to use the RGB input i hope this helps
    :clown:
  6. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    my pioneer 545 has a RGB pass-thru scart and I piggy back an RGB Gamecube signal through it to the TV with no noticable signal degradation.
  7. Greekman
    Greekman
    I think it 's like the old good videos which had 2 scarts so that you could connect another device (like cable decoder or another video ) when old TV's had only one scart .
